rf t1500 1bd amp
livinloud247
Member - Posts: 33
Posted: August 05, 2009 at 2:51 PM / IP Logged
Will the RF T1500-1BD amp blow 2 12" RF T1's at 1-ohm? The guy said he has the 2 subs (2 4-ohm DVCs) wired to 2-ohms with this amp? I didn't think that was possible for one, and two, I'm afraid the power would blow these speakers. Sending 750 RMS a piece when they are only rated at 600?
Platinum - Posts: 13,726
Posted: August 05, 2009 at 6:47 PM / IP Logged
He probably paralleled the coils on each speaker and connected each speaker to the amp individually.  In his mind he had it wired 2 ohms per channel.  In the real world, the amp is a 1 channel amp.  So he had it wired 1 ohm.  The only way to achieve a 2 Ohm load at the amp would be to use only one voice coil per woofer.
Sunday, May 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
