clarion eqs746
imupabove
Copper - Posts: 369
Posted: August 15, 2009 at 3:23 AM / IP Logged
what exactly will it do for me and for sound wise?
here is what i have:
ida-x200
mrp-m500
12" alpine type-r
rf punch 240x4
infinity speakers (front)
alpine speaker (rear)
rf 1 farad cap
btw, someone is selling it to my for 43 bucks.
DYohn
Moderator - Posts: 10,741
Posted: August 15, 2009 at 10:34 AM / IP Logged
It's an EQ.  It provides tone control.
imupabove
Copper - Posts: 369
Posted: August 15, 2009 at 11:32 AM / IP Logged
what does this exactly mean?
DYohn
Posted: August 15, 2009 at 11:51 AM / IP Logged
An EQ (equalizer) is a glorified bass and treble control.  It is intended to allow the user to correct for system deficiencies and change the tonal characteristics of a system.
No, it won't make your system louder and if used incorrectly they can make it sound much worse (and cause clipping.)
imupabove
Copper - Posts: 369
Posted: August 15, 2009 at 1:57 PM / IP Logged
in your opinion, what are the key basics of having a loud car audio system?
DYohn
Posted: August 15, 2009 at 2:10 PM / IP Logged
There really is only one thing that you need pay attention to whether you want a loud system or if you simply want a system that sounds good: proper system design.   Just buying a bunch of gear and putting it together can create something that is decent, but if you really want it to be loud or if you really want it to sound good, or perhaps if you want a little of both, you need to start with the vehicle and then design a system for it from the ground up.
imupabove
Copper - Posts: 369
Posted: August 15, 2009 at 2:12 PM / IP Logged
i already have the vehicle. i just need some pointers.
DYohn
Posted: August 15, 2009 at 2:38 PM / IP Logged
What are your system goals?  Do you want to build a competition db dragster or a great sounding every day driver?
imupabove
Copper - Posts: 369
Posted: August 15, 2009 at 3:15 PM / IP Logged
"a great sounding every day driver" kind sir.
DYohn
Posted: August 15, 2009 at 5:28 PM / IP Logged
I'd begin by hiring the best car audio shop in your area and working with them to design a system customized to your car.  Hire someone who will let you work with them so you can learn as you go.  The best first step is upgrading the vehicle's electrical system as much as possible and doing the best possible sound deadening job.  Remove the vehicle's entire interior and treat the sheet metal, including the roof and paying special attention to the doors and firewall.  Eliminate as much road noise and engine noise as you can.  Test and eliminate interior components vibration as much as you can.  Then create the best front seat sound stage you can afford, using the cleanest electronics you can find (lowest distortion) and a good set of high-quality components properly mounted in the front.  Consider custom pods in either the doors or kick panels.  Then get the vehicle RTA metered and correct anything you need to with minimal EQ or other treatments or by swapping the speakers to correct for deficiencies in your specific vehicle.  Lastly, choose one or two good quality 12" subs and have the best possible subwoofer enclosure designed for it and custom built to fit into your vehicle.  The enclosure is more important than the actual subs you use.  After it's installed meter the car again to achieve the proper balance between the mains output level and the subs.  Note that the subs come last - in order of importance, they are the least important to achieving good sound.  clarion eqs746 -- posted image.  This process may take a few weeks, and you will probably spend at least as much money on the install as you will on hardware.  And have fun!
Page of 6
Saturday, December 27, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
