stereo system, 1992 pontiac bonneville
mstoner
Posted: August 31, 2009 at 3:09 PM / IP Logged
I have a 1992 pontiac bonneville se and ive just recently added a sub system to my car(350 watt kenwood amp, two 10" subs) anyway, i noticed that the rear passenger speaker was not working, but does make a scratching noise when the leads were hooked up, so i checked it on the other side and it works. i think their may be a short i the speaker wires somewhere. what should i do to fix this kind of problem without tearing my car apart?
Platinum - Posts: 13,726
Posted: August 31, 2009 at 8:17 PM / IP Logged
Did you tap into the rear speaker wires to get signal for you amplifier?   If so, disconnect the wires that you connected to that speaker wire and see if your speaker begins to play again.
the12volt
Administrator - Posts: 3,959
Posted: August 31, 2009 at 9:13 PM / IP Logged
Topic moved to the Car Audio forum.
stereo system, 1992 pontiac bonneville -- posted image. the12volt • Support the12volt.com
mstoner
Posted: September 01, 2009 at 5:54 PM / IP Logged
i have already checked that and it didnt do anything. the problem seems to only persist to the rear passenger speaker. its the same problem as the amp where only the left sub worked and the right didnt.
mstoner
Posted: September 01, 2009 at 6:44 PM / IP Logged
what should i do to figure out this problem. i dont want to wait till something bad happens.
Posted: September 02, 2009 at 5:52 AM / IP Logged
It appears as though you may have damaged one of the output chips in your factory radio.  When you were connecting the Line Out Converter, did you have the radio turned on?
mstoner
Posted: September 03, 2009 at 12:20 PM / IP Logged
i had this installed by TAS electronics. i checked it out and everything was in place. im guessing it was like this even before i added the subs. its very confusing as to why it is doing this to me
