choosing a box for subs
flatlineboi55
Member - Posts: 12
Posted: September 24, 2009 at 7:17 PM / IP Logged
i have 2 12inch L7s that are going to be powered by a hifonics brutus 1600 watt amp and are wired at a 1 ohm load... im not really good with the whole port tuning and box building thing so im buying a pre made box for my L7s and jus need help on which one to choose. i only listen to rap and hiphop if that matters.
the 1st box is 4.0ft^3 which is the cubic feet or somethin im guessin and is tuned at 32hz
the 2nd box only shows that it is tuned at 38hz and not the cubic feet or watever
my question is the lower I go basically the louder it will be but will lose sound quality..
I want it to be loud so im leanin with the 32hz box but will I mess anything up as far as the subs and will it sound totally horrible compared to the higher tuned box.
i really want those deep bass tones..
any info or advice would be a BIG help and i would appreciate it thank you very much
blackcivichatch
Copper - Posts: 229
Posted: September 24, 2009 at 7:25 PM / IP Logged
Its actually the opposite.. The closer the box's tunning is the the Fs of the sub, the flatter response you're gonna get. The boxes that are tuned higher will prolly give you more output while the ones tuned lower will give you cleaner sound
UNLABELED Custom Car Club President
flatlineboi55
Member - Posts: 12
Posted: September 24, 2009 at 7:43 PM / IP Logged
heres the links to the each
tuned at 32hz
tuned at 38hz
so the 38hz would be louder
aznboi3644
Gold - Posts: 2,600
Posted: September 24, 2009 at 7:58 PM / IP Logged
i would custom build one
Custom Enclosure Design
blackcivichatch
Copper - Posts: 229
Posted: September 24, 2009 at 8:00 PM / IP Logged
I agree. But if youre not so good with the volume and port design, the custom one can end up far worse than the pre fab
flatlineboi55
Member - Posts: 12
Posted: September 24, 2009 at 8:20 PM / IP Logged
Okay so if I was to have one mad wat would the specs be as far as tuning or wat info I would need to give to have it made .... wat is the highest hz I should go
whiterob
Copper - Posts: 351
Posted: September 24, 2009 at 8:21 PM / IP Logged
tuned at 32hz
tuned at 38hz
ebay links won't work here...
I second getting a custom enclosure made. If you do not know how to make one properly then I would suggest having someone else make it. Local car audio shops can build you one. Otherwise there are many people who build these for good prices online or even locally.
A custom enclosure is almost always going to be better if it is built properly so I would always recommend that over prefab.
flatlineboi55
Member - Posts: 12
Posted: September 25, 2009 at 12:09 PM / IP Logged
So how low should I go with
flatlineboi55
Member - Posts: 12
Posted: September 26, 2009 at 10:50 AM / IP Logged
Ok so one of my friends knows how to make boxes but I'm not sure do I jus follow the specs on the instruction manual for the box or jus let him do his own thing
blackcivichatch
Copper - Posts: 229
Posted: September 26, 2009 at 11:07 AM / IP Logged
Have your friend build the box to be 3 cubic feet in volume for each woofer. And it should be tuned at 34Hz for the best sound.
Monday, December 1, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
