subwoofer/amp wiring
ls/vtec
Member - Posts: 16
Posted: December 13, 2009 at 11:37 PM / IP Logged
hey I have a few questions. I am not too familar with this forum setup so bare with me...
I have the following setup.
-Pioneer Avic N1
-2 Alpine Type R 12's
And Kicker zx850.2 amp.
Now I was told if I hook the subs up as 2ohm it will be louder,but has a chance of over heating the amp. Basically what I want to know is if I hook them up as 2ohms will everything be able to handle it. Or will it it blow the amp or subs? Or am I better off just bridging the setup? And leaving it 4ohms?
Loke I said please bare with me I am not an audio tech nor anywhere close to it. So just looking for input from people who know. Thanks in advance!
j.reed
Copper - Posts: 716
Posted: December 13, 2009 at 11:54 PM / IP Logged
You can run 2 ohm stereo or a 4 ohm bridged with that amp. Both are safe and stable. Both would yield the same power and output. Doing the 4 ohm bridge would be better for this case though being subs, giving you a mono out. A 2 ohm bridge would shorten the life of the amp if it will even run at all.
subwoofer/amp wiring -- posted image.
ls/vtec
Member - Posts: 16
Posted: December 14, 2009 at 11:16 AM / IP Logged
Ok. Thank you for the quick response. So I will leave it at 4ohm, and bridge the amp to both subs. Thank  a lot!
ls/vtec
Member - Posts: 16
Posted: December 14, 2009 at 2:16 PM / IP Logged
Ok so I bridged  each speaker to the amp, and whats happening now is no sound out of the subs and they randomly trun on for like 1 second and the amp light goes to protect mode. But when I wire em up normal each speaker to each channel it works fine. Im confused lol.
j.reed
Copper - Posts: 716
Posted: December 14, 2009 at 2:36 PM / IP Logged
What ohm load are your subs. You have them wired wrong. Are they dual 2ohm or 4ohm?
ls/vtec
Member - Posts: 16
Posted: December 14, 2009 at 3:10 PM / IP Logged
I will upload a pic of how thay are wired in like 10min. i will go puill one off. But heres so you get an idea. i will make you a diagram in  ms paint. It wont be pretty tho lol.
ls/vtec
Member - Posts: 16
Posted: December 14, 2009 at 3:20 PM / IP Logged
[IMG]https://i648.photobucket.com/albums/uu202/typeref/typerwiring.jpg[/IMG]
ls/vtec
Member - Posts: 16
Posted: December 14, 2009 at 3:21 PM / IP Logged
Here's the link. Sorry just realized I can't post pix do to being a noob.
https://i648.photobucket.com/albums/uu202/typeref/typerwiring.jpg?t=1260825636
j.reed
Copper - Posts: 716
Posted: December 14, 2009 at 3:59 PM / IP Logged
Well your subs are dual 4ohm. You were wired Parallel/parallel. So your amp was seeing a 1ohm bridged load. Each needs to be run in series then parallel. 4ohm DVC sub wire optionsYou will want to wire according to OPTION 2 for each sub.
Once your subs are each in series by them self. You will parallel them to the amp.
Series/parallel Again Option 2 is how it should look.
ls/vtec
Member - Posts: 16
Posted: December 14, 2009 at 4:40 PM / IP Logged
Ok. have the 2 outter connections as negative and positive, then the 2 middles connected to each other is that right? Sorry I took a pic and my phone didn't save it. Now if that is right do I need to bridge it to the amp, Or run each to each channel? Again thanks for the halp I know im probably annoying.
Saturday, November 8, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
