1995 chevy van speakers
b1mmuo27
Member - Posts: 37
Posted: January 01, 2010 at 5:44 PM / IP Logged
I am replacing the dash speakers in my newly acquired 1995 chevy 1 ton van. The drivers side speaker is the easy one. Any easy way to get at the passenger side one to remove & replace it? Thanks
frydchkn
Copper - Posts: 60
Posted: January 21, 2010 at 12:49 AM / IP Logged
I have always ripped them out from the top of the dash, and cover the holes with a grill. It looks cooler at the end.
mustyk@att.net
Copper - Posts: 132
Posted: January 21, 2010 at 6:31 AM / IP Logged
Actually the dash has to be removed to access the right speaker. Sounds like a lot of work but not really! I have owned three of these vans and have upgraded speakers in all. First remove all 10mm headed screws under the edge of the dash-(five or six) Second, drop column down-(two large bolts) Third, remove all phillips screws along the top of dash. You should be able to pull the dash back far enough to access both speakers easily
GOOD LUCK!
thetopinstaller
boogeyman
Silver - Posts: 359
Posted: January 21, 2010 at 10:37 AM / IP Logged
yeah the dash has to be removed....a pita....but not to bad in addition to the above you have to remove the A-Pillars, I did in my case anyway
