titan factory auxillary plug wiring?
joseph7071
Member - Posts: 6
Posted: January 07, 2010 at 12:27 PM / IP Logged
I'm trying to convert the factory stereo aux plug to rca so that it will work with aftermarket headunit.  Does anyone have a diagram of the factory aux harness?  Thanks for any help.
autoevolution
joseph7071
Member - Posts: 6
Posted: January 07, 2010 at 12:28 PM / IP Logged
It is an 08 nissan titan.
autoevolution
Platinum - Posts: 13,725
Posted: January 07, 2010 at 1:25 PM / IP Logged
Do you have an ohm meter?  If so plug your 1/8 to 1/8 cable into the jack, and use the meter to determine which wire is connected to whick pin of the 1/8 inch plug.  The tip of the plug is left channel the middle section is right channel and the base is shield.
joseph7071
Member - Posts: 6
Posted: January 07, 2010 at 2:01 PM / IP Logged
Thanks for the info,  i had just figured it out by trial and error before i read your response, but the next one will sure be easier with that knowledge.
autoevolution
Friday, February 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
