vented box?
efx3307
Member - Posts: 25
Posted: February 04, 2010 at 11:27 PM / IP Logged
i jus bought two kicker cvr10 07 series there two ohm. i want to build a vented box for them but have no idea on what frequency to tune them nor what size the box should be. been in car audio for a while but this is my first experience building a vented box. if any one has had a good setup with these subs before it would be helpful. thanks guys
Bentley
j.reed
Copper - Posts: 716
Posted: February 04, 2010 at 11:56 PM / IP Logged
Page 12 will show you the projected freq curves for the 1.25cuft, 1.5cu.ft. and 1.75cu.ft ported enclosures. Page 22-24 will show you the enclosure designs used. Also some other nice building tips in there explaining port folding and basic construction. Sealed enclosure are also covered in that manual.
Kicker CVR tech manual.
vented box? -- posted image.
efx3307
Member - Posts: 25
Posted: February 05, 2010 at 9:17 AM / IP Logged
i have two subs what adjustments should i make to those dimensions
Bentley
DYohn
Platinum - Posts: 10,741
Posted: February 05, 2010 at 11:31 AM / IP Logged
Double them.
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
