2006 impala, subwoofer
hennessy11
Posted: May 20, 2010 at 10:15 PM / IP Logged
Hey guys, first post on the site.
I am upgrading from a 2001 to a 2006 impala. I have an amp, subs, and After Market deck in my '01. I really like the features of the Stock '06 deck so I will be looking into selling the after market deck. However, I would still like to install the Subs/Amp. I was just wondering what all I would need to do/buy. I know the stock deck doesn't have RCA outputs for the Subs.
-Line Converter?
roadshop570
Copper - Posts: 128
Posted: May 20, 2010 at 11:37 PM / IP Logged
Yes, install the loc, at the rear speakers is the easiest but you may want to install behind the deck if you plan on changing the radio out later, use the rear speaker outputs which should be yellow-/brown+ and light blue-/blue+, let me know how it goes, Chadillac
Chadillac
hennessy11
Posted: May 22, 2010 at 5:50 PM / IP Logged
oh ok gotcha. doesnt sound too complicated. I am curious about loss of sound quality. Will I hear a dramatic drop off in the intensity of the subwoofer? Obviously, there will be some but hopefully not too much
icearrow6
Copper - Posts: 497
Posted: May 22, 2010 at 7:39 PM / IP Logged
as far as subs go, I wouldn't worry about "sound quality" loss. LOL.
I suggest installing the converter at the radio.
roadshop570
Copper - Posts: 128
Posted: May 24, 2010 at 12:15 PM / IP Logged
An amp with a flexable crossover and bass remote would be helpful when using the factory radio.
Chadillac
hennessy11
Posted: June 17, 2010 at 12:34 PM / IP Logged
anybody have a particular output converter that has worked well for them? I don't want to buy just any one.
racerjames76
Silver - Posts: 581
Posted: June 26, 2010 at 10:56 AM / IP Logged
Pac makes some decent models. If you are using the stock radio, i suggest getting a LOC that includes a remote turn on wire. One less thing to fuss with.
To master and control electricity is perfection. *evil laugh*
roadshop570
Copper - Posts: 128
Posted: June 27, 2010 at 2:52 PM / IP Logged
If you dont mind paying, audiocontrol's OEM intergration models offer LOC's with EQ and bass boost options.
Chadillac
morebass4u
Posted: June 28, 2010 at 2:04 PM / IP Logged
What I would recommend is that you find a LOC (line output converter) that uses transformers. The cheaper ones use resistors and can melt under extreme usage. They will also put more of a load on your head unit causing it to run hotter. The better LOCs using transformers have a high input impedance and will not load down your head unit.
If you are going to make a scene, be seen and heard!
dr12volt
Sunday, November 9, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
