4 speakers , 2 subs, 4 channel amp
spiknek
Member - Posts: 23
Posted: September 02, 2010 at 11:08 PM / IP Logged
Well I like to install 2 fronts 2 rears and 2 subs using my 4 chennel amp can I do this and is so whats the best way to get it done?
what channels to use with what speakers and or subs and should I wire the speakers and or subs to get best sound possible?
Please advise.
thanks to all
spiknek (Hans
spiknek
Member - Posts: 23
MonteCarlo 2001
DYohn
Platinum - Posts: 10,741
Posted: September 03, 2010 at 11:54 AM / IP Logged
Not going to sound very good.  Simpify your system or pony up for additional amplifiers, or at least one additional amp for your subwoofers.
spiknek
Member - Posts: 23
Posted: September 03, 2010 at 1:52 PM / IP Logged
Even if I connect front and reat parallel into chnl 1 and 2 on hi level and use chnl 3 and 4 on lo level for the subs?
stevdart
Platinum - Posts: 5,816
Posted: September 04, 2010 at 9:16 PM / IP Logged
even if.
get the amps you need.  We've all started the same way, with the same idea.  It doesn't pan out.
spiknek
Member - Posts: 23
Posted: September 04, 2010 at 9:33 PM / IP Logged
so then best thing to do is stay with the 1200watt amp for the front and rears and get another one for the subs maybe another 1200 watt one or something less powerful please advise
randy8876
Posted: September 06, 2010 at 11:45 AM / IP Logged
If you're short on funds this works fine. You'll lose your F/R fade and won't have peak quality, but it gives you some tunes while saving for a sub amp. I'm using a JL HD600 for my entire system until I get an HD750 to power my subs.
You'll still need to wire up everything like both amps are there, so it doesn't really save you much except the temp cost of buying one amp.
DYohn
Posted: September 06, 2010 at 11:54 AM / IP Logged
What are the makes/models of your amp(s) and speakers?
spiknek
Member - Posts: 23
Posted: September 06, 2010 at 11:15 PM / IP Logged
well am running a set that is a replica of kicker 10" subs 6x9's 6.5's for the front and a 1200 watt amp
DYohn
Posted: September 07, 2010 at 8:36 AM / IP Logged
That tells me nothing.  Makes and model numbers might help (and please read the forum rules.)
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
