terminal block spliters
lemar
Member - Posts: 9
Posted: March 09, 2011 at 9:27 AM / IP Logged
Hi All.
I am going to be running multiple speakers off each channel on my amp and I was wondering if you can buy Terminal block splitters which 1 wire will go in and 2 will come out. obviously I can just do this with electrical tape but thought it would look better and be a more professional install with blocks.
If they do exist what are they called and could someone give me a link.
Many thanks.
Luke.
ExtremeProAudio
Member - Posts: 45
Posted: March 09, 2011 at 11:58 PM / IP Logged
I just insert separate speaker wires into the terminal on the amp when I install multiple speakers on one channel.
DYohn
Moderator - Posts: 10,741
Posted: March 10, 2011 at 9:41 AM / IP Logged
Or use a barrier terminal strip if you want.
lemar
Member - Posts: 9
Posted: March 14, 2011 at 2:16 PM / IP Logged
I've decided to use normal terminal block and split the 1 copper wire into a fork and put each into separate terminal blocks. then run each separate block to the separate speakers.
Sunday, November 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
