wire two 4ohm dvc subs to amp
tak4
Copper - Posts: 76
Posted: April 02, 2011 at 11:48 PM / IP Logged
So I have two 12" Kicker CVRs that are 4ohm DVC @ 800rms (total)
I also bought a Kenwood KAC-9105D 1800watt mono that does 900rms @ 2ohms. But I was told that i cant wire it to 2ohm, only 4ohm or 1ohm.
In the specs on the Amp it says "stable 1ohm - Yes" does that mean I can wire my subs to 1ohm load and wire to the amp just fine?
I cant seem to find an answer to this problem.
DYohn
Platinum - Posts: 10,741
Posted: April 03, 2011 at 9:19 PM / IP Logged
Yes that amp is rated as 1-ohm stable.  Make very sure you set your gain properly.
