10 w7 enclosure for small truck
ddiggler357
Posted: June 15, 2012 at 9:14 PM / IP Logged
Anybody had any luck putting one of these in a single can pu without using fiberglass ??? All I found was a couple failures when I searched. If anyone has any ideas , pics , words of I would be so freaking grateful...
soundnsecurity
Gold - Posts: 2,720
Posted: June 15, 2012 at 10:32 PM / IP Logged
you could make a center console box. you can make a custom bass tube from industrial PVC, you can go as far as cutting out the back wall for a blow-through box if you have a bed cover of any kind. it all depends on how badly you want it installed. i see you are in louisiana so if you are in the new orleans area then i can help you personally.
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
