amp switch repair
ncc74656
Copper - Posts: 71
Posted: February 26, 2013 at 2:52 PM / IP Logged
i bought an eclipse amp for pretty cheap on craigs list and it has an issue with its switches to select mono/stereo and low pass/high pass filter. they are less than solid and cause the amp to cut out while driving due to vibrations. where can i buy replacement switches for this and or would de soldering them and simply using jumpers be an acceptable fix?
the amp is used for my mids and highs and is a Eclipse 34320 2 channel amp
here are two pictures of the amp/ switches im talking about.
switch pic
amp pic
thanks
oldspark
Gold - Posts: 4,913
Posted: February 27, 2013 at 12:04 AM / IP Logged
There may be other switches that can be used. It's initially a matter of finding what pin pitch/spacing they use.
Tuesday, December 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
