Posted: February 10, 2014 at 8:05 PM / IP Logged
Posted: February 17, 2014 at 10:05 PM / IP Logged
Posted: February 17, 2014 at 10:25 PM / IP Logged
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
Is the turn off pop comming through all the speakers or is isolated to just the subs or door speakers? I just did a complete system in a '13 silverado and got no pop at all, I was also using a metra harness and a kenwood double din though.
It would also be a really good idea to use a relay off the rap shutdown wire instead of tying straight in to a low current ignition wire, without looking it up I believe rap power is yellow at the BCM somewhere (maybe the green plug if i remember right) and you can grab 12v at the driver dash end cap it's RED / white.
