Can-Bus low speed emulator for radio turn
congoman
Member - Posts: 29
Posted: September 08, 2015 at 9:16 PM / IP Logged Link to Post Post Reply Quote congoman
Hey all!
It's been a while since my last visit. I wanted to share some info on something I tinkered with and seems to be work. I don't know if anyone has tried this, but if you wanted to power up a can-bus radio to bench test, you would need a Can high-low signal from a device in order for the unit to boot up. I simply used an Axxess ASWC-1 interface used as a can switch signal to power up my VW factory radio. It should be the same with any Can signal unit from any car make. Have fun.
icearrow6
Copper - Posts: 497
Posted: September 09, 2015 at 11:24 AM / IP Logged Link to Post Post Reply Quote icearrow6
Nice find!
Would it be too much trouble to ask you for a simple diagram of how you achieved this?
congoman
Member - Posts: 29
Posted: September 10, 2015 at 2:13 PM / IP Logged Link to Post Post Reply Quote congoman
Ok, so the wiring is simple. Essentially, you'll just need 4 wires from the ASWC-1....
red       (12 volt)
black     (ground)
pink      (can high)
pink/blue (can low)
The last 2 wires may be reversed if it doesn't detect. You will need to locate the can wires coming out of the radio your're working with. Mine happens to be a VW but you can cross reference the pin-out from Axxess website for the specific car. Hope that helps!
icearrow6
Copper - Posts: 497
Posted: September 10, 2015 at 3:51 PM / IP Logged Link to Post Post Reply Quote icearrow6
Thanks for sharing. I wish i could give you some rep points or something here... lol.
Again nice work
