2012 F-350 Super Duty Accessory Lead?
kc2llw
Member - Posts: 12
Posted: December 06, 2018 at 8:06 PM / IP Logged Link to Post Post Reply Quote kc2llw
Hello,
I am installing a pioneer AVH radio and backup camera using a Xsvi-5521-nav wiring kit but can’t seem to get the 12v key on power to the radio. I replaced the stock non sync am/fm cd with the pioneer but only see constant battery power but no delayed accessory power. Can someone please let me know where I can tap accessory power? I am also looking for the reverse wire for my backup camera. Any help would be greatly appreciated
Steve
geepherder
Platinum - Posts: 3,668
Posted: December 06, 2018 at 8:20 PM / IP Logged Link to Post Post Reply Quote geepherder
Check the purple/green wire at the ignition harness.
Platinum - Posts: 13,725
Posted: December 07, 2018 at 8:48 AM / IP Logged Link to Post Post Reply Quote i am an idiot
You may not need the XSVI harness. A 70-5520 is what it calls for. Your radio harness may have a switched wire in it. If there is a grey/blue wire in the factory harness that is right next to a larger grey/red wire, connect your red radio wire to the grey/blue.
kc2llw
Member - Posts: 12
Posted: December 07, 2018 at 11:57 AM / IP Logged Link to Post Post Reply Quote kc2llw
I don’t recall seeing grey/blue I will have to pull the radio out again
kc2llw
Member - Posts: 12
Posted: December 07, 2018 at 4:22 PM / IP Logged Link to Post Post Reply Quote kc2llw
Took the unit out again no grey blue wire. Check all the others some had 25.33 volts?? Found a white and blue wire near parking brake with key on 12.18 volts used it now head unit is working
tonanzith
Gold - Posts: 603
Posted: December 08, 2018 at 9:50 PM / IP Logged Link to Post Post Reply Quote tonanzith
2012 Ford F-350 (80-Bit) - North America
        Item Wire Color Polarity Wire Location
          12 Volts Green/Red (15A) + Ignition Switch, black 7 pin plug, pin 4
          Second 12 Volts Red (125A) + BCM in passenger kick, black 1 pin plug (G), pin 1
          Ground (chassis ground)
          Starter Blue/White + Ignition Switch, black 7 pin plug, pin 7
          Ignition White/Orange + Ignition Switch, black 7 pin plug, pin 1
          Accessory Violet/Green + Ignition Switch, black 7 pin plug, pin 6
          Keysense Blue/Gray + Ignition Switch, black 7 pin plug, pin 5
          CAN Bus High White/Blue (HS CAN) Data OBD-Data Link Connector, black 16 pin plug, pin 6
          CAN Bus Low White (HS CAN) Data OBD-Data Link Connector, black 16 pin plug, pin 14
          CAN Bus High 2 Gray/Orange (MS CAN) Data OBD-Data Link Connector, black 16 pin plug, pin 3
        CAN Bus Low 2 Violet/Orange (MS CAN) Data OBD-Data Link Connector, black 16 pin plug, pin 11
        RX DATA Yellow/Orange Data
PATS Transceiver on ignition switch, black 4 pin plug, pin 4
          TX DATA Violet/Gray Data
PATS Transceiver on ignition switch, black 4 pin plug, pin 3
          Power Lock blue/green -
driver kick or BCM in passenger kick, black 26 pin plug (C), pin 6
          Power Unlock yellow/violet -
driver kick or BCM in passenger kick, black 26 pin plug (C), pin 8
          Lock Motor gray/brown 5 wire BCM in passenger kick, 32 pin plug (D), pin 26
          Driver Unlock Motor blue/green 5 wire BCM in passenger kick, 32 pin plug (D), pin 21
        Passenger Unlock Motor violet/gray 5 wire BCM in passenger kick, 32 pin plug (D), pin 31
        Factory Alarm Arm violet/green and yellow/green (driver door both - driver kick or BCM in passenger kick, blk 26 pin plg (C), keypad) pins 18, 11
        Factory Alarm Disarm (see disarm no unlock)
        Disarm No Unlock
(transponder, ignition, and acc; see TechDoc 1098)
          Parking Lights yellow/blue + BCM in passenger kick, gray 10 pin plug (E), pin 6
          Parking Lights - yellow/orange - headlight switch, gray 10 pin plug, pin 2
        Parking Lights Interrupt black/gray (see Tech Doc 1096) cut headlight switch, gray 10 pin plug, pin 3
        Hazards brown/yellow -
hazard switch or BCM in passenger kick, black 52 pin plug (B), pin 32
          Turn Signal (Left) blue/green (F); gray/brown (R) + BCM, green 26 pin plug (F), pin 8; 32 pin plug (D), pin 12
        Turn Signal (Right) yellow/violet (F); violet/orange (R) + BCM, green 26 pin plug (F), pin 7; 32 pin plug (D), pin 15
        Headlight yellow/blue (headlight); black/gray (switch - and cut headlight switch, gray 10 pin plug, pins 7, 3 ground)
          AutoLights violet/green cut headlight switch, gray 10 pin plug, pin 4
          Reverse Light blue/white + BCM in passenger kick, 32 pin plug (D), pin 13
          Left Front Door Trigger green/violet - N.C. BCM in passenger kick, black 26 pin plug (C), pin 9
          Right Front Door Trigger white - N.C. BCM in passenger kick, blk 26 pin plug (C), pin 5
          Left Rear Door Trigger green - N.C. BCM in passenger kick, blk 26 pin plug (C), pin 20
        Right Rear Door Trigger yellow - N.C. BCM in passenger kick, blk 26 pin plug (C), pin 21
        Dome Light gray/violet (dome lamp); violet (puddle + BCM, gray 12 pin plug (A), pin 1; black 26 pin plug (C), lamp) pin 1
        Hood Pin blue/orange - N.C. BCM in passenger kick, green 26 pin plug (F), pin 2
        Tachometer blue ac
Customer Access Harness above driver kick, taped to
   wiring harness
        Note - Tachometer: On models without the Customer Access Harness, go to any fuel injector and use the wire that is not blue (gasoline), or use the camshaft position sensor, which is white/green at the Powertrain Control Module on passenger side of engine, middle, black 98 pin plug, pin 32 (diesel).
     Clutch Pedal
blue/orange
clutch switch, gray 6 pin plug, pin 1
Fuel Pump
yellow/violet (gasoline)
   BCM in passenger kick, green 26 pin plg (F), pin 6
Note - Fuel Pump: On diesel models, use brown/white (+) at the Inertia Fuel Shutoff Switch above the passenger kick, gray 3 pin plug, pin 1.
     Rear Defroster
white/orange
     - latched
right of steering column, black 59 pin plug, pin 15
Mirror Defroster
   (same as rear defroster)
             Left Front Heated Seat
(MS CAN)
      Right Front Heated Seat
   (MS CAN)
             Speed Sense
violet/orange
    ac
Customer Access Harness above driver kick, taped to wiring harness
     Brake Wire
violet/white
   brake switch or BCM in passenger kick, black 52 pin plug (B), pin 28
     Parking Brake
white/violet
     Horn Trigger
violet/green
   horn switch or BCM in passenger kick, black 52 pin plug (B), pin 33
Wipers
   (LIN bus)
             Left Front Window (Up/Down)
blue/gray - yellow/violet (w/o one-touch up only)
    A
master window switch, gray 8 pin plug, pins 5 - 1
     Right Front Window (Up/Down)
brown/yellow - green/orange(w/o one- touch up only)
      A
   driver kick, door harness
     Left Rear Window (Up/Down)
blue/orange - yellow
      A
Right Rear Window (Up/Down)
gray/violet - brown/green
   A
Note - Right Rear Window (Up/Down): The power sliding rear window open/close are purple/brown - yellow/orange (5 wire) at the overhead console switch, gray 12 pin plug, pins 4 - 9.
     Sun Roof (Open/Close)
violet/brown - yellow/orange (func w/ign on only)
overhead console switch, gray 12 pin plug, pins 6 - 8
     Memory Seat 1
violet/white
Memory Seat 2
   yellow
     Radio 12V
gray/red
radio, gray 24 pin plug, pin 1
Radio Ground
   black/blue
    radio, gray 24 pin plug, pin 13
     Radio Ignition
gray/blue (base audio); (MS CAN on premium audio)
radio, gray 24 pin plug, pin 2
     Radio Illumination
violet/gray (dimmer)
   radio, gray 24 pin plug, pin 3
     Factory Amp Turn-on
violet/red (sub amp); brown (audio amp)
   radio, gray 8 pin plug, pin 4; gray 24 pin plug, pin 7
Left Front Speaker (+/-)
white - white/brown
   radio, gray 24 pin plug, pins 8 - 21
Note - Left Front Speaker (+/-): On models with amplifier, the speaker wires are white - white/brown at the audio amplifier under the driver dash, gray 14 pin plug, pins 13 - 6.
Right Front Speaker (+/-)
white/violet - white/orange
radio, gray 24 pin plug, pins 11 - 12
Note - Right Front Speaker (+/-): On models with amplifier, the speaker wires are white/purple - white/orange at the audio amplifier under the driver dash, gray 14 pin plug, pins 11 - 4.
Left Rear Speaker (+/-)
white/green - brown/yellow
radio, gray 24 pin plug, pins 9 - 22
Note - Left Rear Speaker (+/-): On models with amplifier, the speaker wires are white/green - brown/yellow at the audio amplifier under the driver dash, gray 14 pin plug, pins 12 - 5.
     Right Rear Speaker (+/-)
brown/white - brown/blue
radio, gray 24 pin plug, pins 10 - 23
            Note - Right Rear Speaker (+/-): On models with amplifier, the speaker wires are brown/white - brown/blue at the audio amplifier under the driver dash, gray 14 pin plug, pins 10 - 3.
             Subwoofer (+/-)
violet/green - green/white (preamp)
blue/green - white/green (without SYNC)
radio, gray 8 pin plug, pins 1 - 2
        Aux. Audio Input Left (+/-)
blue - yellow/green (without SYNC)
radio, gray 16 pin plug, pins 7 - 8
              Aux. Audio Input Right (+/-)
radio, gray 16 pin plug, pins 6 - 14
RSE Video (+/-)
white/green - brown/violet (rear camera video)
radio, gray 10 pin plug, pins 1 - 6
RSE Audio Left (+/-)
blue - gray/orange (SYNC audio)
radio, gray 16 pin plug, pins 1 - 2
RSE Audio Right (+/-)
violet/green - brown/white (SYNC audio)
radio, gray 16 pin plug, pins 9 - 10
        Satellite Radio 12 Volts
(built into radio)
      What Fits?
   Item
   Size
     Depth
Location
   Headunit
    double DIN
        center of dash
   Left Front Speaker
    6x8
      4
   left front door
   Right Front Speaker
    6x8
      4
   right front door
   Left Rear Speaker
    6x8
      3
   left rear door or left rear pillar
   Right Rear Speaker
    6x8
      3
   right rear door or right rear pillar
Satellite Radio Tuner
(built into radio)
Gary Sather
Sunday, January 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
