New toy...New problem
Sweekster
Silver - Posts: 481
Posted: June 11, 2003 at 10:14 AM / IP Logged
Hey guys,
I got an issue I could use some help on.
Me being the wonderful husband I am,  I bought my wife a  2000 Toyota 4 Runner SR5 for her birthday.  I'm happy with it but I have one issue.  The sound system has almost no bass. The truck has 2 tweeters up by the mirrors and speakers in each door (I haven't taken it apart to verify the full set up yet.  I just got it yesterday)  Any suggestions on how I should go about adding bass?  I plan on keeping the factory CD head unit and building on that.   I was thinking of maybe adding an amp with speaker level inputs and preamp outputs to power the door speakers and another amp to power a small (8 inch) sub.  But how would I trigger the amps to turn on when the radio turns on?  It doesn't have a power ant.  Any Ideas?
esmith69
Gold - Posts: 1,511
Posted: June 11, 2003 at 10:43 AM / IP Logged
Just use the +12 volts swtiched wire that turns the head unit on.  It should be able to power on 3 components (radio + 2 amplifiers) with no problem.
I think you will be happy with just adding the subwoofer to the system.  As long as it can play the higher bass frequencies you won't need to amplify the door speakers.  You'll be able to turn the  bass down on the head unit and that'll let you play the system louder before it distorts.  So basically what I'm saying is adding a subwoofer will make the whole system more efficient.New toy...New problem -- posted image.
Ethan
Donate to the12volt.com
Sweekster
Silver - Posts: 481
Posted: June 11, 2003 at 12:09 PM / IP Logged
Wow, that' s most definetly a better way to go (thanks).  But how would I get the sound signal to the amp so that  I can run the sub?  I'm not sure that the factory radio has low level outputs.  Would I still use an amp with speaker level inputs?
chasesaccessori
Copper - Posts: 198
Posted: June 11, 2003 at 12:52 PM / IP Logged
Yes. Or use a High to low converter.
wvsquirrel
Gold - Posts: 1,237
Posted: June 11, 2003 at 9:37 PM / IP Logged
If the amp you get has High Level inputs, then you can tap straight from the speaker wire into the amp. If the amp only has Low Level inputs (RCA), then you would need a Line Out Converter like this one. I'm not trying to sell that one, but it is a good unit. It converts a High Level amplified signal into a Low Level non-amplified signal. IMO, the LOC is the way to go unless you get a different headunit with RCA pre-outs.
Squirrel
"No more Cpt. Kirk chit chat"
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
