illumination light wire
realitysmaster
Member - Posts: 23
Posted: June 20, 2003 at 7:53 AM / IP Logged
Okay, I have a Delco CD/Cassette/AM/FM stereo installed in an 86 Chevy Nova. Everything has been okay with it and it's been installed for quite some time. Anyhow, the fact is that when the lights are turned on the stereo doesn't illuminate and the lights turn off on the stereo. It turns out that the wire must have turned hot at some point because it sparks when it touches metal. For the life of me I can not figure out how or where the problem is coming from. Could some person help me?
And on a side note here: When it gets really hot outside the stereo will not read the CDs and it kicks the CD out with an error message. I noticed the stereo gets really hot. If anyone can will they tell me how I can alleviate this problem too if possible.
"A man begins cutting his wisdom teeth the moment he bites off more than he can chew."
lncmarkviii
Member - Posts: 24
Posted: June 20, 2003 at 8:49 PM / IP Logged
it sounds like yor best i sto bit ethe bullet and replace the radio, it's just amatter of time before the unit dies on the cd end.. as fa ra syuor illumination problem it sounds like you have a short either behind the radio or in the radio
