Power?
graemesimpson
Member - Posts: 24
Posted: July 08, 2003 at 1:49 PM / IP Logged
Hi,
I have read the various articles relating to Power in I.C.E setups, but, I just want to hear some first hand advice;
I have 2 Amps, 1 @350 Watt (2Ch) and 1 |@ 440Watt (4Ch), the 2 Ch feeds the subs and the 4Ch feeds the speakers.
Now I have built an Amp rack that sits in the front boot of a MR2, so my main Power connecter from the batt (behind amp rack) to the rack itself is only approx 3 to 4 ft, that goes to a 2 way distribution block (30 Amp Fused) which then feeds the Amps.  Forgot to mention from Sitting between Batt and Dist block is a 60Amp fuse (last nights advice).
I have used 8Awg Cable purchased from Maplins (the fancy stuff), given my wattage and the minimal length of the power cable, do you think 8Awg will suffice.  I have no intention of having the system blasting, purely my OWN listening pleasure.
Any advice is really welcome.
Graeme
deftonekorn1002
Member - Posts: 10
Posted: July 08, 2003 at 3:11 PM / IP Logged
check your amp manuals and see what their bottom end recommendation it. i would go at least 2 guage from the batt to distubiton and then the gauge the manufacture recommends
whoaaa
Maxst
Silver - Posts: 866
Posted: July 08, 2003 at 4:23 PM / IP Logged
https://www.the12volt.com/info/recwirsz.asp
look at this chart..follow the rms and length...to find the right size.
I need quality equipment, feel free to donate.
Wednesday, February 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
