4 ch amp but six speakers
Gilateen
Copper - Posts: 61
Posted: July 22, 2003 at 10:50 AM / IP Logged
i have a 4 ch amp (sony xm-404eqx) and i wanted to find out how would i hook up the front, rear and tweeters to it? what would be the best configuration? thanks much
zargon
Copper - Posts: 186
Posted: July 22, 2003 at 10:57 AM / IP Logged
I would run the rears off of one ch and run the tweeters and front speakers off of the other, the amp will be 2 ohm stereo so you will be ok hooking two speakers to one ch, if you are also running subs you can set the x/overs to high pass if not you could run the rears in full range and the fronts in high pass with a x/over frequency of around 100 hz.
zargon ruler of estranorth
Gilateen
Copper - Posts: 61
Posted: July 22, 2003 at 11:07 AM / IP Logged
so i would run the rears on one terminal or on two terminals?
i.e.    + - (L speaker) + - (R speaker) or + - (L & R speakers)
zargon
Copper - Posts: 186
Posted: July 22, 2003 at 11:14 AM / IP Logged
you will use left positive and negitive for the left speaker and right positive and negitive for the right speaker, for the fronts you will combine the left front speaker positive with the tweeters positive and the negitive with the tweeters negitive and do the same on the right side.
Gilateen
Copper - Posts: 61
Posted: July 22, 2003 at 11:48 AM / IP Logged
thanks Z, good looking out!!!
slick 5050
Posted: July 23, 2003 at 1:38 AM / IP Logged
how would you connect a sub to this?
Gilateen
Copper - Posts: 61
Posted: July 23, 2003 at 7:30 AM / IP Logged
good question, how would you hook a sub up to this configuration? using the 4 channel amp above and having front, rear, tweeters and a sub? can anyone provide some insight?
bberman1
Gold - Posts: 2,314
Posted: July 23, 2003 at 10:22 AM / IP Logged
This is how you would run the sub in a trimode configuration http://www.eatel.net/~amptech/elecdisc/trimode.htm But your amp must be tri mode compatible in order for it to work.
Gilateen
Copper - Posts: 61
Posted: July 23, 2003 at 10:31 AM / IP Logged
nice!! but can it work for both front and both rear speakers and with one or 2 subs?
Gilateen
Copper - Posts: 61
Posted: July 23, 2003 at 10:32 AM / IP Logged
Page of 3
Wednesday, November 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
