2003 Honda Civic Preamp Outputs
Infidel
Posted: July 22, 2003 at 11:36 AM / IP Logged
Hi there.
Thanks in advance for the assistance.
Does the CD player contained in the 2003 Honda Civic EX have preamp outputs and remote leads for the installation of an aftermarket amplifier?
I don't want to rip apart my dash to find out.
Regards,
Ed
esmith69
Gold - Posts: 1,511
Posted: July 22, 2003 at 12:04 PM / IP Logged
Are you referring to the separate factory cd player?  Or did the car come with a cd player/radio combo unit?
Either way there's no preamp outputs already in the vehicle.  You'll have to use a 4-channel line output converter if you're installing a 4-channel aftermarket amplifier, or a 2-channel line output converter if it's just a sub amp.
The aftermarket amp's remote turn on connection can be made by just tapping in to the +12v switched wire in the radio's harness.  Here's the wiring info I have for the 03 civic--as always, verify these wires with a DMM first before making connections to them.
BATTERYWHITE+IGNITION SWITCH HARNESS
GROUNDBLACK-RADIO HARNESS
ACCESSORY 01YELLOW+IGNITION SWITCH HARNESS
ILLUMINATIONRED / BLACK+RADIO HARNESS
DIMMERRED+RADIO HARNESS
FRONT LEFT SPEAKERBLUE+
FRONT LEFT SPEAKERGRAY/BLACK-
FRONT RIGHT SPEAKERRED / GREEN+
FRONT RIGHT SPEAKERBROWN / BLACK-
REAR LEFT SPEAKERBLUE / YELLOW+
REAR LEFT SPEAKERGRAY/WHITE-
REAR RIGHT SPEAKERRED / YELLOW+
REAR RIGHT SPEAKERBROWN / WHITE
Ethan
Donate to the12volt.com
Infidel
Posted: July 22, 2003 at 12:09 PM / IP Logged
Just the cd player/radio combo unit that comes standard with the EX.
esmith69
Gold - Posts: 1,511
Posted: July 22, 2003 at 12:11 PM / IP Logged
yea right after I posted my first reply I realized it didn't really matter what type of system it was.  It's not gonna have preouts regardless.  so i updated my post with some more info
Ethan
Infidel
Posted: July 22, 2003 at 12:18 PM / IP Logged
Thanks ethan. I think it's time to purchase a new head unit. I don't like the converters... Unless they've signifigantly improved since I was into this hobby (about 5 years ago).... the sound quality suffered.
Would be nice if I could find a head unit that completely enveloped the slot taken up by the stock head unit... I don't remember if it is the standard size or if I would have to use one of those ugly and cumbersome brackets..
esmith69
Gold - Posts: 1,511
Posted: July 22, 2003 at 10:29 PM / IP Logged
Actually you'd be surprised at how good aftermarket units look when used with this dash kit.  You can hardly even tell the difference.
Ethan
Saturday, January 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
