Where to run power cable
hammondc
Copper - Posts: 112
Posted: September 24, 2003 at 2:29 PM / IP Logged
2000 honda accord 2 door---
Where is a good place in the firewall to run 4 gauge power cable from battery? I cannot find a good place. I am not new to car audio, this just has me stumped. Looking for ideas. Pics would be awesome if you have a similar set-up/
thnx---C
Thugstyle
Member - Posts: 22
Posted: September 24, 2003 at 5:11 PM / IP Logged
above the brake pedal is usually where i install them (I work at circuit city)  usually you will find a gromet there if not drill a new hole but be careful where your drilling
kenmci
Copper - Posts: 161
Posted: September 24, 2003 at 6:42 PM / IP Logged
which side of the car is the battery on and do you have a manual transmission.  If you can't find a place then if you have an automatic then you should be able to drill where the clutch would be if you had one.  Again make sure that there is nothing behind where you are drilling.  This would work only if you have the battery on the drivers side, since you don't want to cross the engine with the power wire.
hammondc
Copper - Posts: 112
Posted: September 24, 2003 at 7:58 PM / IP Logged
it is automatic. and the battery is on driver side.  I just don't know where above the pedal to drill. can you give me an idea??
Tuesday, March 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
