Sebring Ignition WIre
toucansma
Posted: July 17, 2002 at 6:03 PM / IP Logged
I have a 96 Chrysler Sebring (that used to have the infinity system) and I installed new speakers, amp, headunit. Now the ignition wire won't work for the headunit. I tested it with a multimeter. It should be RED / white wire, but nothing works. Any thoughts?
GlassWolf
Copper - Posts: 365
Posted: July 17, 2002 at 8:39 PM / IP Logged
1995-96 Chrysler Sebring Stereo Information
Constant 12V+
Red
Switched 12V+
Blue
Ground
BLACK / YELLOW
Illumination
n/a
Dimmer
GREEN/ YELLOW
Antenna
Left Rear
Front Speakers
6 1/2" Doors
Left Front (+)
WHITE/ Blue
Left Front (-)
BLACK/ Blue
Right Front (+)
WHITE/ Red
Right Front (-)
BLACK/ Red
Rear Speakers
6" x 9" Rear Deck
Left Rear (+)
Yellow/Blue
Left Rear (-)
Gray/Blue
Right Rear (+)
Yellow/Red
Right Rear (-)
Gray/Red
I suggest using a wiring harness so you needn't cut any wires. These are a saviour as well when selling the car if you keep the system.
your RED / wht is a speaker lead. blue is ignition/switched
-GlassWolf
Pioneer Stage-4, Orion, DynAudio, Fi
toucansma
Posted: July 17, 2002 at 9:30 PM / IP Logged
Thanks for in the info, but my Sebring is different. That is for the normal wires, I have that stupid infinity system. Also I know that since I have no solid red nor blue cable(i looked up on other sites for the diagrams). I have tested the wires with a multimeter and only verifed the constant 12v(pink and white). Thats why I was wondering how I can fix the ignition wire. All the help is very appreciated.
toucansma
Posted: July 18, 2002 at 8:40 AM / IP Logged
Anyone have any ideas??? Thanks
Platinum - Posts: 12,488
Posted: July 18, 2002 at 9:27 AM / IP Logged
Take the switched ignition from the steering column ( BLACK/ WHITE ) and run a wire from the HU to this wire.
Tuesday, January 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
