Installing audio system in 2003 GTI
Geisha_Gyrl
Posted: October 31, 2003 at 8:53 AM / IP Logged
Hey, I wanted to know what all needed to be done to install a new head unit, amps, and subs in a 2003 GTI. It comes with the monsoon system. Thanks.
Platinum - Posts: 12,488
Posted: October 31, 2003 at 9:00 AM / IP Logged
You will most likely want to use the OEM wiring if you can ( this will reduce your install time ). The OEM amplifier will need to be turned on or bypassed at the output side of the amp. I suggest using new wire all around , but that's just me.... do it right the first time and you don't have to worry about it.
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
