2001 Oldsmobile Alero
alero03
Posted: November 03, 2003 at 2:30 AM / IP Logged
I'm hooking up a amp in my 2001 Oldsmobile Alero.Can anyone tell me what color wire on the harness I need to hook the remote wire coming from the amp to?Which color wire is the ant. trigger on the radio's harness?
Thanks,
forbidden
Platinum - Posts: 5,354
Posted: November 03, 2003 at 3:08 PM / IP Logged
I am assuming that you have a factory deck and hooking up an aftermarket amp / sub system. Does the car have a power antenna. If it does the wire to trigger the antenna may go to +12v only when the tuner is on, so obviously you do not want this type of wire. Check it with a meter to find out for sure. If this wire is not present, under your steering column you can look for a pink or green wire. This should be a +12v ignition lead, make sure you test this wire with your meter first. It will give you +12v with the keys in the ignition and turned to either start or run.
alero03
Posted: November 05, 2003 at 2:52 AM / IP Logged
Thanks for the reply Rob.Yes I am hooking a amp and subs into the factory Monsoon system.My car doesn't have a power ant.I will check the wires with a volt meter.I was just looking for a short cut by finding out if anybody knows the GM wiring system and the exact wire I should use.
Thanks for your reply,
Jerry
forbidden
Posted: November 05, 2003 at 12:46 PM / IP Logged
I don't have a wire magic for your car, but it is a good bet to base it on a similar car, most gm's do not drastically change the color coding of the wires year to year, I would look for a pink wire under the steering column. This hopefully (meter it to be sure) should be the +12v ignition line to trigger your amp.
Tuesday, December 30, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
