2 batteries
rk.mendoza
Member - Posts: 27
Posted: November 24, 2003 at 10:09 PM / IP Logged
Hey whats up I have a question. I am instaling a 1000bd+ a 551x Rockferd Fosgate amps in my 2003 Chevy suburban. I bought a new optima yellow top for just my system. So it will go from my CAR batt to a SR200 relay then to my optima then back to my system. I have herd that well a Batt for just my system wont help with teh lighst diming and well to much current draw. So I need to knwo what can help me with that nesides a 1 Farred CAP by Rockford Fosgate. and is there any special way I need to install the 2 batts and the cap.
Ronnie E Mendoza
You can do anything you put your mind to.
donkason
Copper - Posts: 189
Posted: November 24, 2003 at 10:19 PM / IP Logged
I have a 99 tahoe with a 140 amp alternator. I have one yellow top battery and a stinger 1 farad cap running 2 soundstream amps. My lights still dim and my voltage still drops. I suggest you purchase a new alternator to handle the power, I will soon. You can have all the battery in the world but if your alt. can't keep up with them it is worthless. It is like filling up a huge pool with a garden hose, then try filling two pools with the same garden hose. It is a mistake even I have made before too. A cap won't help much either because you still are lacking power from the alternator to fill it efficiently. I think you have the large case A.C. Delco alternator. Any good alt. shop should be able to pull 180 to 200 amps out of that with a high output rebuild. Where I go it is about 250 bucks for the rebuild. Good luck
speedwayaudio1
Silver - Posts: 879
Posted: November 24, 2003 at 11:47 PM / IP Logged
yes what he said.
Big Dave
Saturday, August 30, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
