Kicker Comps
Maxmouse1983
Member - Posts: 20
Posted: December 22, 2003 at 9:09 PM / IP Logged
hey yall i have 2 kickers comps 12s 4 ohm stable i wanna the best way i can hook it up.
i have a baja amp that is 400 amps
stable at 2 omhs what sould i do or get a better amp
bberman1
Gold - Posts: 2,314
Posted: December 22, 2003 at 10:40 PM / IP Logged
Are they the 4 ohm model or the 8 ohm?
Maxmouse1983
Member - Posts: 20
Posted: December 25, 2003 at 7:13 PM / IP Logged
hey im sorry they are 8ohms]
bfog99
Copper - Posts: 212
Posted: December 25, 2003 at 7:25 PM / IP Logged
personally i would look into another amp. i am not the biggest fan of baja. since they are 8 ohm speakers, you can wire  then into 4 ohm mono load. according to what i found, they are 150 watts rms each, so 300 total at a 4 ohm load. i would look into the jbl bp600.1 it will put out 300 watts rms at 4 ohms. this one one amp from many that would work. if you want to work with what you have, it would depend on the amp. how many channels, watts per channel, ohms stability per channel. if it is a 2 channel bridge the amp to run the two subs at 4 ohms. if it one channel wire them the same way to the one channel. make sense?
Maxmouse1983
Member - Posts: 20
Posted: December 25, 2003 at 7:34 PM / IP Logged
hey thankx for that i have two channels LF & Rt
i have them right now bridge out. I only use it for that one purpose for lows do u think a american pro could handle it it is 600 watts 4 channel highs and lows
thankx
