Posted: January 28, 2004 at 2:17 PM / IP Logged
Posted: January 28, 2004 at 2:41 PM / IP Logged
Posted: January 28, 2004 at 3:12 PM / IP Logged
Friday, May 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
it says there that this is a DVC sub which if it was: If using Dual 2 ohm coils the total load would be 4.0 ohm.
If using Dual 4 ohm coils the total load would be 8.0 ohm.
If using Dual 6 ohm coils the total load would be 12.0 ohm
this is the way i have my subs wired up right now to my amp(to get 6ohms). my amp can only do 2 ohm stereo, but i have these subs bridged on my amp.
now another one is that this one is a SVC sub: If using Single 2 ohm coils the total load would be 2.0 ohm.
If using Single 4 ohm coils the total load would be 4.0 ohm.
If using Single 6 ohm coils the total load would be 6.0 ohm
this is really confusing cause essientially can i wire up my subs like this
but take out the wireing that connects the voice coils so they would be wired only as SVC to get a 3ohm load. would that be possible?!
