need help?
harvey1959
Copper - Posts: 94
Posted: February 20, 2004 at 4:41 AM / IP Logged
I have a Lightning Audio FF150.2 with the 10 inch sub installed in a  94 Dodge Spirit.  My hu is a JVC KS-FX12 which have no rca output jacks so I am using the speaker level inputs to the amp. I am using the right side rear speaker as input to the amp tying the "+" from the speaker to the Left and Right "+"  and the speaker "-" to the Left and Right "-" of the amp.  Then I have it bridged mono to the 10 inch sub.  Am I shortchanging the input to the sub by using one channel of the hu or should I use both left and right outputs from the hu to the amp?
Harv
DYohn
Platinum - Posts: 10,741
Posted: February 20, 2004 at 10:18 AM / IP Logged
You will only get the bass contained in the right channel, so yes, you may be shortchanging yourself.  Give the amp a stereo signal so you get the full amount of musical information.  It's only speaker wire and a little work.
forbidden
Platinum - Posts: 5,354
Posted: February 20, 2004 at 1:28 PM / IP Logged
That amp is a powerhouse as well, it may be small and inexpensive but it is a performer, Dyohn is bang on as usual with his suggestions.
harvey1959
Copper - Posts: 94
Posted: February 20, 2004 at 8:11 PM / IP Logged
Thanks,  gentlemen.  I figured one of you would say give it the full stereo signal but I wanted to make sure. This was a christmas gift from my daughter and the first bridgeable amp I have owned.  Thanks again
Harv
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
