amp problem
makaveliwi
Member - Posts: 19
Posted: February 27, 2004 at 9:03 PM / IP Logged
My sib keeps cutting in and out. the amp has power and the rest of the speakersa still work.
milwaukee walt
forbidden
Platinum - Posts: 5,354
Posted: February 27, 2004 at 9:14 PM / IP Logged
Turn the gain on the amp down, next check the speaker wire from stem to stern to make sure it is not grounding out.
makaveliwi
Member - Posts: 19
Posted: February 27, 2004 at 10:06 PM / IP Logged
i checked all the conections, the speaker is not grounding out. i installed the amp and sub two days ago and it was working fine, today i turned the gain on the amp up a little and now it is acting funny. i turned the gain back down now. the sub stays on when the deck is at low volumes, but if you turn it up a little, then the sub starts cutting out. it is constantly cutting in and out.
milwaukee walt
forbidden
Posted: February 27, 2004 at 10:10 PM / IP Logged
Can you try a different sub on the amp? and double check the rca cable for groundouts as well. When the sub is cutting in and out, is the amp going on and off or in and out of protection?
makaveliwi
Member - Posts: 19
Posted: February 27, 2004 at 10:17 PM / IP Logged
i have a kenwood amp, it has a blue light on it, the light stays on constant while the stereo is on. the amp doesn't enter protection mode at all. my amp is rated at 800 watts and the sub is an MTX thunder 6000. the rcas are fosgate twisted pair, how do you check if the deck is giving an output through the rca jacks? i don't have another sub to test it with right now. the sub is pretty old, do you think that i possibly blew it?
milwaukee walt
forbidden
Posted: February 27, 2004 at 10:22 PM / IP Logged
It may have a flat spot on the voice coil, do you have a meter? Run a new temporary rca cable from the cdplayer to the amp overtop of the seats, it can be attached to the sub preout or the front / rear preout. By testing this way it will also check the output on the cd player.
makaveliwi
Member - Posts: 19
Posted: February 27, 2004 at 10:24 PM / IP Logged
i don't have meter until work tomorrow. thank you for your help. do you think that my problem is either the rca's or my sub?
milwaukee walt
makaveliwi
Member - Posts: 19
Posted: February 27, 2004 at 10:25 PM / IP Logged
what does flat spot mean?
milwaukee walt
forbidden
Posted: February 27, 2004 at 10:27 PM / IP Logged
A worn part on the voice coil that shorts out as the sub cone moves up and down, thus causing the sub to cut in and out. You might have a bad sub or a rca cable that is grounding out and maybe, just maybe a cold solder joint in the amp, this I doubt, it sure looks like the RCA or sub.
makaveliwi
Member - Posts: 19
Posted: February 27, 2004 at 10:33 PM / IP Logged
the amp is brand new two days ago. everything else is old. thank you again for your help. if the sub has a flat spot will the ohm check be any different? how can you tell by looking at it. will there be any spots or discolorations on the sub. Any recommendations for a new sub?
milwaukee walt
