need for a crossover
tee17
Copper - Posts: 93
Posted: March 01, 2004 at 6:55 AM / IP Logged
i would like to know if there is an actual need for a crossover. i have a punch 800 that i am putting on three pioneer 12's and i have an 840 watt power acoustik amp for my high. do i actual need to put a crossover in this setup and if so what would be the correct way to wire it
DYohn
Platinum - Posts: 10,741
Posted: March 01, 2004 at 10:56 AM / IP Logged
Assuming you are using the low-pass crossovers built into the sub amp, no you don't NEED a seperate crossover.  Will it give you better setup flexibility and potentially sound better?  Yes.  It's up to you.
kure
Copper - Posts: 69
Posted: March 01, 2004 at 8:24 PM / IP Logged
suppose your speakers come with an external crossover like infiinty, but they are not adjustable
would it sound alot better to add a electronic crossover or jus use the one on the amp
customsuburb
Gold - Posts: 1,813
Posted: March 01, 2004 at 8:29 PM / IP Logged
If you buy a high quality one from some one like AudioControl then it will. These usually include line drivers also that make your preamp singal stronger which = less noise = better sound.
