Do I have my subs wired correctly?
tnrplaya
Copper - Posts: 58
Posted: March 08, 2004 at 11:04 AM / IP Logged
Hello everyone,
I wanted a second opinion on my wiring before I install my box terminals, can somebody take a look at this and tell me if it looks right, I want to run a 4 Ohm final load.
Thanks!Do I have my subs wired correctly? -- posted image.
PG Limited Edition Octane Aplifier
PG Ti400.2
(2) JL12w6v2
Focal 165KF
JL TR-690TXi
Sony XAV-7W
Sony 10 Disc MP3 Changer
X-box
APC 350W inverter
Monster 1/0
Irragi 180A Alternator
superstreet786
Silver - Posts: 339
Posted: March 08, 2004 at 11:40 AM / IP Logged
im almost positive that goes to a 2 ohm load but wait for someone elses opinion cuz i dont know all haha
---- 1996 Chevy S10 ----
1 Lightning Audio S2.600.2 Amp
2 Lightning Audio 12" Subs
1 Lightning Audio 1 Farad Cap
astro88
Copper - Posts: 195
Posted: March 08, 2004 at 12:43 PM / IP Logged
Yup 2 ohm load if in fact thos subs are 4 ohms each
Fosgate3
Copper - Posts: 328
Posted: March 08, 2004 at 1:00 PM / IP Logged
I concur, it's a 2 ohm load if both the subs are wired at 4 ohms. Are the subs single or dual voice coil?
brad123
Member - Posts: 18
Posted: March 08, 2004 at 1:52 PM / IP Logged
Actually that is a 8 ohm load.  Because each sub is running at 4 then you are putting it into the terminal so 4 and 4 is 8.  To get to a 2 ohm load you need to run a positive from one sub to the next and then to the terminal and for the negative do the same.  So it goes from amp to terminal then to 1 sub and then it links to the next.  if not you are going to be pulling 8 ohms.
Brad
Prophit
Copper - Posts: 79
Posted: March 08, 2004 at 2:08 PM / IP Logged
I would just wire this up normally.. I think then you might be running at 4ohms..
forbidden
Platinum - Posts: 5,354
Posted: March 08, 2004 at 2:47 PM / IP Logged
If these are single voice coil subs then it is a 2ohm mono load. If they are dual 4 ohm subs wired in series to 8 ohms each, then you have drawn the correct diagram for a 4 ohm mono load.
tnrplaya
Copper - Posts: 58
Posted: March 08, 2004 at 4:21 PM / IP Logged
they are jl audio 12w6v2, each is a DVC jumpable to either 8 or 2 ohms...so ROB, i should jump them to 8Ohms a piece, then using the diagram above, I'll be at 4 Ohm final load?
here's info
thanks
PG Ti400.2
(2) JL12w6v2
Focal 165KF
JL TR-690TXi
Sony XAV-7W
X-box
APC 350W inverter
Monster 1/0
forbidden
Posted: March 08, 2004 at 4:41 PM / IP Logged
Yes.
bfog99
Copper - Posts: 212
Posted: March 08, 2004 at 4:42 PM / IP Logged
the subs you have are dual 4 ohm voice coils. if you wire them to 8 ohms each then hook it up as the diagram above shows with the box terminals, then you will end with a 4 ohm total load.
Saturday, April 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
