Line out coverter
Krazzyborri
Copper - Posts: 56
Posted: March 14, 2004 at 4:53 PM / IP Logged
OK FELLOW AUDIO ENTHUSIASTS.. I HAVE A 1993 LEXUS ES300 AND IM PUTTING TOGETHER A CUSTOM SYSTEM. I LIKE THE LOOK OF THE FACTORY RADIO SO I WAS THINKING OF ADDING LINE OUTPUT CONVERTERS. DOES ANYONE KNOW OF SOME HI QUALITY CONVERTERS? OR DOES ANYONE TOTALLY DISAGREE WITH THE FACTORY RADIO IDEA?
THANX
Teamrf
Gold - Posts: 1,031
Posted: March 14, 2004 at 5:07 PM / IP Logged
Well the big deal with the fac. radio is the voltage the radio puts out. If you are not looking for anything too loud go with the loc. If not get an aftermarket radio.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
superstreet786
Silver - Posts: 339
Posted: March 14, 2004 at 8:26 PM / IP Logged
any converter will do but if u want total control over ur system get aftermarket, you cant do much with factory
---- 1996 Chevy S10 ----
1 Lightning Audio S2.600.2 Amp
2 Lightning Audio 12" Subs
1 Lightning Audio 1 Farad Cap
customsuburb
Gold - Posts: 1,813
Posted: March 14, 2004 at 8:46 PM / IP Logged
The aftermarket route would be the best idea if your putting together a pretty good system. Who would want to put together an excellent system only to not let your amps and speakers perform their best because of the head-unit? Most LOC have the same quality of output, I guess you could add a line driver to the LOC but it still wouldn't sound as good as something like an Eclipse head-unit's excellent rca outs.
Krazzyborri
Copper - Posts: 56
Posted: March 15, 2004 at 12:44 AM / IP Logged
THANKS FOR ALL THE OPINIONS. I'LL DEFINETLY TAKE ALL THAT INTO CONSIDERATION.
KRAZZYBORRI........
stevdart
Platinum - Posts: 5,816
Posted: March 16, 2004 at 10:40 PM / IP Logged
You can get excellent sound quality using the factory HU.  I'm using mine and it's as good as, if not better than, any aftermarket head.  Difference is, the install is much more time-consuming.
Check out David Navone's engineering http://www.davidnavone.com/detail.asp?PRODUCT_ID=N-774V
He recommends twisted cable from the factory speaker leads and connecting the LOC close to the amp.  You can email him for specifics.
