amps
southside
Copper - Posts: 220
Posted: March 18, 2004 at 2:40 PM / IP Logged
 i need a good amp, that will power 4 12 in cerwin vega v- max subs.dvc 800w  max power. i have boughten sony amps for so long that i got no idea anymore. so suggestions would help thanks.
southsider
southside
Copper - Posts: 220
Posted: March 18, 2004 at 2:41 PM / IP Logged
 also i want it to be a mono amp too.
southsider
AudioBAHNvlcm
Copper - Posts: 209
Posted: March 18, 2004 at 2:54 PM / IP Logged
you wanna a mono amp to power 4 12"s?
forbidden
Platinum - Posts: 5,353
Posted: March 18, 2004 at 2:59 PM / IP Logged
A Rockford 1501BD would be a good amp for this application. 1500 w x 1 rms @ 2ohm mono, the exact load that 4 dvc 4 ohm subs wired in a series / parallel circuit will present.
southside
Copper - Posts: 220
Posted: March 18, 2004 at 3:00 PM / IP Logged
or at least something that make my sh*t go boom. so any suggestions would be helpful.
southsider
forbidden
Posted: March 18, 2004 at 3:11 PM / IP Logged
The box is what will make the bite, not just the amp.
southside
Copper - Posts: 220
Posted: March 18, 2004 at 3:15 PM / IP Logged
so that rockford bd if i run those subs in paralell will break that ohm load down to two?
southsider
southside
Copper - Posts: 220
Posted: March 18, 2004 at 3:16 PM / IP Logged
so i will need one or two of those amps forbidden? an thank u for your advice i really appreciate it.
southsider
southside
Copper - Posts: 220
Posted: March 18, 2004 at 3:19 PM / IP Logged
would this amp work because ROCKFORD FOSGATE
2000 WATT RMS SUBWOOFER AMPLIFIER
i think there switching over to these now
southsider
forbidden
Posted: March 18, 2004 at 3:27 PM / IP Logged
Link won't post for me. Anyways, your subs if they are dual 4 ohm voice coils can each be wired in series to create a single 8 ohm load for each sub. Then all 4 subs wired in parallel create a 2 ohm mono load. Rockford amps 99% of the time make more power than they claim, I would expect this amp to produce closer to 1700 watts rms @ 2 ohm mono (the 1501bd that is). If the link you posted is for the T20001bd then that amp will work just fine as well.
Monday, July 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
