10w6v2 problem
snowdeath
Member - Posts: 32
Posted: March 25, 2004 at 6:35 PM / IP Logged
OMG HELP! I have two 10w62 in a custom sealed box. As I was listening to them today I heard a weird noise coming from them. I went back and looked at them and one of the sub's foam has ripped around the cone. It has gone about halfway around it... The subs are about three months old.
Has anyone else heard of this type of problem from w6v2's?
customsuburb
Gold - Posts: 1,813
Posted: March 25, 2004 at 7:15 PM / IP Logged
What amp is powering those subs? I know JL will set you  up with some new subs if you bought them from an authorized dealer and they are only 3 months old.
snowdeath
Member - Posts: 32
Posted: March 25, 2004 at 9:37 PM / IP Logged
I'm using a directed 1500d amp
stro720
Member - Posts: 11
Posted: March 25, 2004 at 9:44 PM / IP Logged
seen it happen lots of times in sealed boxes. with different types of subs
what do you think would happen if you hooked that wire to that wire :D
Ravendarat
Platinum - Posts: 2,806
Posted: March 25, 2004 at 9:51 PM / IP Logged
I have seen that happen on JL drivers before on all sorts of series of subs. If they are from an auth dealer just go back and they will give you a new one.
94bonny
Copper - Posts: 108
Posted: March 26, 2004 at 9:39 AM / IP Logged
yea hopefully you bought from a authorized dealer, if so you will be able to get a new sub under the warranty since its only 3 months old...
Alpine cda 9813
jl 500/1
eclipse aluminum 15"
snowdeath
Member - Posts: 32
Posted: March 26, 2004 at 10:26 AM / IP Logged
Is there anyway to fix a sub like this? Also how does this happen so I can prevent this in the future...
thepyrofish
Member - Posts: 36
but if you've got no warranty on it whatsoever, go spend $5 on a tube of silicone and have fun
