Fuses?
ravenndude
Silver - Posts: 250
Posted: March 30, 2004 at 8:00 AM / IP Logged
I jsut added an MTX 4244 amp to my system to power the I believe I blew a fuse. I didn't have time to check where the fuse got blown. I now have 4ga wire from the battery to the trunk then into a fused distro block that has 8ga wire comming from it. The other amp that i have is a RF 360.2 punch. That's a total of 560watts RMS and around 1120watts MAX. Also there are two 25 amp fuses on the back of the MTX and a 40 amp fuse in theback of the RF.
What size Fuses should i use for the Distro block (it's one 4ga that splits to two 8ga with 2 fuse holders) and what fuse should i use for the fuse holder under the hood?
Disaster092
Copper - Posts: 54
Posted: March 30, 2004 at 8:06 AM / IP Logged
I believe you would need a 100amp fuse under the hood, and probly two 50 or 60 amps in the d-block. Someone correct me if i'm wrong.
Jay T
Copper - Posts: 169
Posted: March 30, 2004 at 10:01 AM / IP Logged
Ya that sounds right.  100 amp under the hood.  Distro block needs 40 or 50 amp fuses for each amplifier.  Under the "basic" section there is a calculator / pie chart thing for finding amp / watts / volts conversion.  Just take your max draw and fuse it at the battery and then max draw for each  amp and fuse at the distro block.  I think when you need to round it you can round down to the next available fuse size.
Thack79
Silver - Posts: 526
Posted: March 30, 2004 at 10:42 AM / IP Logged
here is another calculator.  http://www.bcae1.com/
superstreet786
Silver - Posts: 339
Posted: March 30, 2004 at 7:58 PM / IP Logged
get a 100 amp circuit breaker... circuit breakers are the best for the car audio people that do lots and lots of work on theyre system cuz its just a switch
---- 1996 Chevy S10 ----
1 Lightning Audio S2.600.2 Amp
2 Lightning Audio 12" Subs
1 Lightning Audio 1 Farad Cap
