Gound noise, Strange
Ravendarat
Platinum - Posts: 2,806
Posted: April 05, 2004 at 7:01 PM / IP Logged
Ok the subject is a 90 tercell. The problem, ground noise out of just the front left speaker. It is rpm related noise. The system is a pioneer 7300 deck, orion cs100.2 connected to spl 4 inch speakers, pheniox line driver connected to a orion 150.2 which runs a single 4 ohm MTX 12". What I have dont to trouble shoot. All the standard stuff, you know like check grounds, rca's etc. I tried switching the 100.2 for the 150.2 and it still did it, I also even disconected the amps from the speakers all together so there was no signal going through them and there was still the noise. I replaced all the wire running from the back of the car to the crossovers and from the crossovers to the speakers and the noise continues. the power wire runs down the drivers side of the car and the speaker wires run along the rcas on the passanger side. The speaker wires then travel accross the dash to the crossover and then on to the speakers. This is riving me insane because I cant hink of what else to try. I also checked to see if the terminals on the speakers were even close to touching anything and they wernt but to be sure I even taped up the terminals on the speakers. I was a little desperate by this point because this whole situation stopped making sense to me when I unhooked the amps all together. Any one with insite on this, and would like to shed some light on the situation, I would be very appretiative.
lspker
Silver - Posts: 503
Posted: April 05, 2004 at 8:45 PM / IP Logged
If I understand you correctly, you disconnect the speaker wire at the amp and still get whine through the speaker.  Assumming that you don't have mixed up wires,  dissconnect wires into the crossover and start your car.  If whine is still there, dissconnect other side of crossover, try again.  Either the crossover or wire is actting like an anntenna and picking up ingition noise.  Relocate or reroute wires.  Check spark plug wires, cap for any voltage leakage.
stevdart
Platinum - Posts: 5,816
Posted: April 05, 2004 at 8:47 PM / IP Logged
You eliminated, as a potential problem:   noise from the amp (both).  The noise may  be picked up at the crossover.  Can you switch wires at the two dash crossovers and see if the noise then comes from the right speaker?
forbidden
Platinum - Posts: 5,354
Posted: April 05, 2004 at 9:00 PM / IP Logged
The noise will be generated from the crossovers, move the crossover totally away from any engine computer, speaker magnet, power / ground wire and see what you have for noise. I have come across this before and it baffled me for years until I figured it out by accident one day (long before forums existed - cough  cough I must be getting old). I have also had singing crossovers, something I have been trying to duplicate for years now, yet no luck.
DYohn
Moderator - Posts: 10,741
Posted: April 05, 2004 at 9:21 PM / IP Logged
Indeed, crossovers are a likely source, but I've also seen this with a stray strand from a speaker wire touching ground.  In one very strange instance I had a speaker system (not in a car) playing an AM radio station sitting there all by itself with nothing at all connected to it.  It turned out to be a shorted capacitor in the crossover.
Ravendarat
Posted: April 06, 2004 at 12:59 AM / IP Logged
tried switching the crossovers from side to side. pulled the crossovers out on the floor of the car away from everythin and it still did it.
DYohn
Posted: April 06, 2004 at 8:17 AM / IP Logged
Bad ignition wires, coil or sparkplug?
Ravendarat
Posted: April 06, 2004 at 10:37 AM / IP Logged
mabye, but isnt it usually a popping noise, not a whine, when its the ignition wires, and wouldnt it be both speakers?
DYohn
Posted: April 06, 2004 at 10:49 AM / IP Logged
Yes, but you never know.  When all the normal stuff has been eliminated, you have to start looking for the weird stuff.  Have you tried pulling the speakers out of the doors and seeing if they whine when they are, say, sitting on the floor?  It could be some sort of electrical signal in the door that the speakers are picking up.  Does the car have power windows?  If so, try pulling the fuse for the windows and see if the problem goes away.  If it is electrical induction noise from something in the doors, sounds like a good candidate for kick panels...  Also, try eliminating the line drivers.
stevdart
Posted: April 06, 2004 at 10:56 AM / IP Logged
At this point you might consider going through these steps:
1-  disconnect the speaker wire ( to the offending speaker) at the amp.  Noise in door?  Yes-not the amp or its inputs or grounds.
2-  Use a separate test speaker.  Disconnect speaker wire at the crossover input, connect to test speaker.  Noise in door?- Yes- eliminates wire to crossover.
3- Connect speaker input back to crossover.  Disconnect the output side, then jump to test speaker.  Noise in door?- eliminates crossover.  Noise in test speaker?- noise originating in the crossover.
Thursday, January 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
