Alpine V-Drive amplifier
swamprat323
Gold - Posts: 1,335
Posted: April 17, 2004 at 12:30 AM / IP Logged
On these head units with the V-drive amp. They required a 10 gauge wire kit. My question is. What if you are NOT using the internal amp, do you still need to use a 10 gauge wire.
Kyle
sonicsound
Copper - Posts: 100
Posted: April 17, 2004 at 9:54 AM / IP Logged
no you do not need to use a 10 guage wire if you are not using the amp.  All you will be using the HU for is running CD's and and the crossovers inside the HU.  And really all you need for wire for the HU is another wire hooked up to your 12V wire in your ignition harness to tap into the yellow 12V wire of the HU.  Hope that helps...
Sonic
Pioneer AVH-P4000DVD
Zapco 360.4
Zapco 500.1
Zapco SP-4SL Processor
Two JL 10 W3v3d2
Alumapro 15 Farad Cap
