deck install
anothacivic
Member - Posts: 7
Posted: May 04, 2004 at 3:21 PM / IP Logged
Okay, here's the story, my gf's deck got jacked and the thieves cut the stock connector, so there's a mess of wires, I hard wired everything to the metra connector harness and plugged it in. the 7.5 amp fuse blew under the hood, I put another one in, it blew.  So Right now I have a 15 amp fuse in there and hasn't blown yet.   What harm can this do? Im actually a newbie when it comes to audio electronics.  Someone told me that I may have to wire something straight from the fuse  and use a 10 amp fuse at most in the slot??? I HAVE NO IDEA HOW TO DO THIS..SOMEONE HELP!!!
customsuburb
Gold - Posts: 1,813
Posted: May 04, 2004 at 4:33 PM / IP Logged
NEVER PUT BIGGER FUSE SIZES IN THEN THE ORIGINAL. You are asking for a fire.
kickerstang
Copper - Posts: 180
Posted: May 04, 2004 at 5:33 PM / IP Logged
take it to a stereo shop and have them hardwire it for you, don't risk frying anything
what!?!?! you want some??
Ravendarat
Platinum - Posts: 2,806
Posted: May 04, 2004 at 5:50 PM / IP Logged
F F F F F F F F F F F F F F F FIRE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Not good, dont do it. Seek Pro's to fix the problem
DYohn
Moderator - Posts: 10,741
Posted: May 04, 2004 at 5:56 PM / IP Logged
What fuse did you blow and then increase?  What is the head unit you installed?  Some heads simply draw more current than others.  If the fuse you blew is the factory radio fuse, then the above admonisions about possible smoke and flames are right on.  :)  Never, never, never just keep putting in bigger fuses until it doesn't blow any longer.  That is, well, stupid.  Sorry.  If it is a fuse that was previously installed for another head, then perhaps you simply need to put the CORRECT one in for the system you now have.
forbidden
Platinum - Posts: 5,354
Posted: May 04, 2004 at 6:41 PM / IP Logged
Have a look at www.installdr.com to verify that you have hard wired to the proper wires. Cut wires, larger fuses blowing, obese chicks hitting on me for a better deal, all these things and more bring shivers to my spine.
Sweekster
Silver - Posts: 481
Posted: May 04, 2004 at 8:59 PM / IP Logged
forbidden wrote:
...obese chicks hitting on me for a better deal, all these things and more bring shivers to my spine.
Glad to know 'm not alone.
Duane...
If you think you're confused, imagine how you feel.   deck install -- posted image.
