Amp Installation
4x4store
Member - Posts: 11
Posted: August 29, 2002 at 7:39 AM / IP Logged
This is my first time doing an amp installation, I want to make sure I am doing it right.....
I have 2 rockford fosgate amp 250watts and 2 bass boxes with 10 rockford sub woofers.
2 gauge power wire from the battery to a distribution block.
8 gauge from the distribution block to the amps
run a ground distribution block for the amps.
Now do I connect a Y connector to the sub output on the back of the head unit?
Do  i use a butt connector to connect the 2 rem wires together then run one wire to the back  of the headunit?
The 4x4 store plus More
If you drive it we customize It....
mobiletoys2002
Gold - Posts: 1,050
Posted: August 29, 2002 at 8:36 AM / IP Logged
You want to run one wire from the head unit and then take that remote wire go into the first amp then just jump a wire off that amp in to the next. If your radio has an independent sub out then take that set of rcas back to the first amp and use the line out of that amp to feed the second no need for a y connector.
Sagrox2000
Member - Posts: 14
Posted: August 29, 2002 at 8:42 AM / IP Logged
while jumping from one amp to the other with the remote wire, you probly need to put a relay in the wire coming from the head unit to the amp on the remote wire to boost the signal strength. Do this because you dont need a weak signal.
Later,
Dantax
"Alpine Is The Top Dog"
monsoon-bad
Member - Posts: 20
Posted: August 30, 2002 at 12:44 PM / IP Logged
I'm running 3 amps amd have grounded EACH one by themselves.
You want the shortest ground wire for each amp.
Jason73
Posted: September 02, 2002 at 12:19 PM / IP Logged
You will be safe by jumping the remote wire from the amps. But if you use the same remote wire to operate more than 4 itmes the I would add a relay to boost the voltage!
mobiletoys2002
Gold - Posts: 1,050
Posted: September 09, 2002 at 12:26 AM / IP Logged
You would be adding current capability the voltage never changes, just tring to clarify that jasonAmp Installation -- posted image..
Saturday, November 8, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
