Will these specs. make a good sub?
chevyman26
Copper - Posts: 227
Posted: May 28, 2004 at 3:04 PM / IP Logged
 Regardless of peoples opinions of brand names, how do these specs sound for a sub, and who would make something with similar specs?
Fs.....29.9Hz         Re........3.7 Ohms          Qms......9.0          Qes.......0.422           Qts......0.404
Vas.....28.46 L       Mms.....168.36 g           Cms.....168.4 uM/N            BL.....16.64 Tesla-M
SPL.....85 dB          Sd......345 cm2              X max.....35mm p-p
power hndling - 450W RMS, 600 Peak
Thanks in advance for the opinions of the pros...
You'd better get me out of this lord... or else you'll have me to deal with. -- Hunter S. Thompson "F.A.L.I.L.V."
bdl666
Silver - Posts: 330
Posted: May 28, 2004 at 3:34 PM / IP Logged
What size is it ?
From the specs you posted the sub should give you a very flat response down to 28hz on a vented 1cubic foot enclosure tuned to 29 hz. Who makes this sub because regardles of what brand it is, it looks good for a home sub.
sandt38
Copper - Posts: 60
Posted: May 28, 2004 at 5:27 PM / IP Logged
Unless there is something special about the motor, I'd say it wouldn't be too bad, but not really overly special. Without any Le specs transient responce is difficult to predict. The driver appears to be best suited for ported applications, which I am not a big fan of. The MAX, Brahma, XXX, W7, GTi, and a few others using treated motor/suspensions with a borderline/favoring ported woofer still do well in sealed. I am more of a sealed guy myself, so I would likely not be buying one. But overall it looks OK.
chevyman26
Copper - Posts: 227
Posted: May 29, 2004 at 4:56 AM / IP Logged
it's a 10" . I planned on using a sealed box in the interest of saving room. Factory specs say use sealed between .3 and .55 cu. ft.. or vented for SPL =.75 cu ft.w/ 3in. Vd & 13.5" Vl  or SQ = 1.0 cu. ft. w/2" Vd & 9.5"Vl.
DYohn
Platinum - Posts: 10,741
Posted: May 29, 2004 at 9:24 AM / IP Logged
The 85 db efficiency rating would turn me off.
sandt38
Copper - Posts: 60
Posted: May 29, 2004 at 5:14 PM / IP Logged
Efficiency is such a bogus #. Too many Mfgs twist this spec. put your 2.83 volts to a 4 ohm load, and your efficiency goes up 3Db. It was still the proper voltage applied, but the lower load tweeks the spec.
I would not seal this driver. the 30 Hz FS and low QTS lead me to believe it will not do very well in a sealed box.
bdl666
Silver - Posts: 330
Posted: May 29, 2004 at 7:44 PM / IP Logged
What brand is it ?
 Like I said it looks good for a home sub.
chevyman26
Copper - Posts: 227
Posted: May 31, 2004 at 7:03 PM / IP Logged
sorry so long to reply. It is a Phoenix Gold Ti10. Just wanted to hear some opinions before I gave up the name.
Saturday, February 21, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
