Aiwa CDC-X237
Importdude
Copper - Posts: 55
Posted: June 11, 2004 at 6:52 PM / IP Logged
well. this deck works but the left rear doesnt want to have sound.....
does this mean its totaly toast?
or can it be fixed
tia
Maygiver024
Posted: July 12, 2004 at 6:59 PM / IP Logged
Try swaping wires left to right see what happens speakers could be shorted out or bad connections, troubleshoot b4 coming to conclusions, if when u swap right read dosent work then u have a bad output on the deck amp.
While your back there pls if you have time write down the pin locations for power and speakers etc.  i'm using a sony wiring harness in an Aiwa deck and i dont want to fry it.  Number left to right if you were looking at the back of the deck 2 rows thanks in advance and good luck.
Maygiver
raydawg357
Silver - Posts: 769
Posted: July 13, 2004 at 12:33 PM / IP Logged
Check your speaker, just because it plays with the factory HU, doesn't mean it will play with the AIWA.  The Aiwa puts out more power and a bad speaker will not play.
Do it right the first time
