Sub enclosure Messed Up!
teampimp
Member - Posts: 19
Posted: September 12, 2002 at 1:36 AM / IP Logged
I just recived a 4x10" sub enclosure. I checked out the mount holes and they are not symmetrical, It's to wide for the screws in some areas! They wont fall thru or anything.
Is there any way I repair this?
(mounting bracket of some kind or silicone)
Help please!
Thanks for your time
eedukes
Member - Posts: 33
Posted: September 12, 2002 at 7:38 AM / IP Logged
 I am not sure I follow you. Are the subwoofer holes too big to allow the screws to grab wood when the subs are installed? .........I would not recommend using silicone sealant around the gasket of the sub as this may void the warranty, depending on what kind of sub it is. If you must use some type of sealant around the sub use rope caulk or plumbers putty.
crroush
Copper - Posts: 151
Posted: September 12, 2002 at 9:46 AM / IP Logged
The holes that are there, that are not correct (ie in the wrong place, you can fill them with bondo, or even wood putty and then just drill new holes and screw in the sub (predrill first).
I would recommend building your own enclosures in the future, that is if you have the tools and what not, you can make such a better product from a lot cheaper.
teampimp
Member - Posts: 19
Posted: September 12, 2002 at 3:49 PM / IP Logged
I got another enclosure today from a "real" professional.
It's a Down firing enclosure!
I'll try and up load a pic asap.
thanks guys,
Platinum - Posts: 12,488
Posted: September 12, 2002 at 7:06 PM / IP Logged
Make a new top sheet that will have the holes the right size. Doesn't matter if the old one is still there... just nail it over top of it and refinish the box.
Saturday, March 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
