Running 12v Trigger for multiple amps
tnrplaya
Copper - Posts: 58
Posted: July 30, 2004 at 7:54 PM / IP Logged
Hey everyone,
I am going to be running some wires for my upcoming install this weekend. I was wondering how I should run the 12v trigger for the 3 amps that I have, should I run 1 wire front to back and daisy chain or splitt off of that? should I run 3 seperate wires front to back? I thought I read a while back that the 12v trigger needs to be fused or relayed or something...can't quite remember. Any help would be greatly appreciated.
Also, I assume that i should run the trigger along the same side of the car as my power cable. And run any signal cable down the other side. Am I correct in thinking this?
See my signature if you need to know what equipment I am running
Thanks in advance for helping out a newbie!
~Alvin
PG Limited Edition Octane Aplifier
PG Ti400.2
(2) JL12w6v2
Focal 165KF
JL TR-690TXi
Sony XAV-7W
Sony 10 Disc MP3 Changer
X-box
APC 350W inverter
Monster 1/0
Irragi 180A Alternator
tnrplaya
Copper - Posts: 58
Posted: July 30, 2004 at 7:58 PM / IP Logged
Oops.
My sig dosent show that I am running a PG ti400.2 in addition to the Limited Edition Octane. BTW the octane needs 2 seperate 12v triggers, it is essentially two 400.2's build onto one chasis...seperate power, ground, and triger for both sides. So I will need to trigger a total of 3 amps.
thanks for the help!
~Alvin
PG Ti400.2
(2) JL12w6v2
Focal 165KF
JL TR-690TXi
Sony XAV-7W
X-box
APC 350W inverter
Monster 1/0
dudek38
Copper - Posts: 250
Posted: July 30, 2004 at 10:31 PM / IP Logged
it doesnt matter if u run the remote wire on the rca side since it such low current. also just run one wire and connect it to one amp, then run jumpers to each amp. it doesnt need to be fused, just hook them up w/ radio or switch off.
owner of
Motion Marine & Car Audio
the florida keys
Ravendarat
Platinum - Posts: 2,806
Posted: July 30, 2004 at 10:34 PM / IP Logged
You should probally use a relay on the remote line.
Sound Pressure
Silver - Posts: 711
Posted: July 31, 2004 at 12:26 AM / IP Logged
I agree with raven. I would normally run a remote on a max of two devices, anything more than that I would use a relay to be safe. As far as the wires I usually run the power wires together on one side and the rca's and speaker cables on the other.
Sound Pressure
mob.dynam.grad
Copper - Posts: 73
Posted: July 31, 2004 at 12:47 AM / IP Logged
you should always fuse a power wire...get a fuse just under the wire gauges max current carrying capabilities.
tnrplaya
Copper - Posts: 58
Posted: July 31, 2004 at 4:21 PM / IP Logged
any elaboration on how to relay a remote wire for 3 amps?
thanks everyone
~Alvin
PG Ti400.2
(2) JL12w6v2
Focal 165KF
JL TR-690TXi
Sony XAV-7W
X-box
APC 350W inverter
Monster 1/0
kgerry
Platinum - Posts: 3,455
Posted: July 31, 2004 at 4:41 PM / IP Logged
 87 to 12 Volts, 85 to ground, 86 to remote out from deck & 30 to remote terminal on amps....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
