FM CD Changer installs
swede
Copper - Posts: 125
Posted: August 11, 2004 at 12:21 AM / IP Logged
Does it matter WHERE the in line antenna modulator is connected? I have a wagon and there's a storage bin in the farthest corner back right under where the antenna leads come in from the outside.  The CD changer would fit perfectly there and I was thinking of just connecting the adapter right there as well.  Its a power antenna so I wasn't sure if there'd be any interference issues either.
It would save running the cable all the way to the front.
Subtlety is EVERYTHING.
raydawg357
Silver - Posts: 769
Posted: August 11, 2004 at 11:12 AM / IP Logged
That will work perfectly as long as your commander will reach to the front of the vehicle.  I do this with most vehicles that are equiped with power antennas.  You have the antenna, constant, switched and ground wires all right there.
Do it right the first time
swede
Copper - Posts: 125
Posted: August 11, 2004 at 2:35 PM / IP Logged
Thanks very much. I'm *hoping* the controller will reach. Its a new Kenwood MP3 I ordered but haven't received yet, so I'm not even sure how everything looks, length, etc.... yet.
The later wagons omitted the power antennas (because they were a constant source of failure problems) and integrated the antenna into the rear side window. I got a later window with all the hookups at a yard, so the power antenna motor, et al, will be gone freeing up the whole compartment for this changer. SO....its the perfect - and subtle - spot for it.
FM CD Changer installs -- posted image.
Thanks again.
