speaker box to big
northballer
Copper - Posts: 57
Posted: August 19, 2004 at 9:27 PM / IP Logged
My speaker box has too much volume what should I do to fix it or can anything even be done
amlloyd
Member - Posts: 11
Posted: August 19, 2004 at 9:51 PM / IP Logged
sell it and buy a new one or break it appart and use the wood.
Maxst
Silver - Posts: 866
Posted: August 19, 2004 at 10:04 PM / IP Logged
drop some ledge like wood peices on the sides and center  then make a panel(s) to fit in there then seal it up really well.
I need quality equipment, feel free to donate.
stevdart
Platinum - Posts: 5,816
Posted: August 19, 2004 at 11:43 PM / IP Logged
This happens quite often...subs are inverted where once they were installed normally;  a change in subs from what you used to have...As long as you use a solid filler, as Maxst suggested, to take up the air space, you can use the same enclosure.  A good material to use is a common brick.  Also, pieces of 2X4 can be glued into the box.  Find the amount of space that is over specs.  It will probably be a value in cubic feet.  Multiply by 1728 and you'll have cubic inches.  Measure the dimensions of the filler pieces you want to glue into the box to amount to the proper cubic inch sizes.
Monday, April 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
