question about amp?
xploder21
Member - Posts: 44
Posted: August 27, 2004 at 2:24 PM / IP Logged
The third day after I hooked my system up, one bridged channel on my amp just didn't power my sub. The other sub was hitting like normal. I got home and opened the amp up and saw no bad components and even used an oscope to check curves on diodes and other semiconductors. I put the amp back together and swapped the connections to subs meaning the left sub connected to the bad side and the other sub to the good one. Both subs are now hitting. I was wondering what happened or if it was because I just fixed a bad solder joint somehow.
kgerry
Platinum - Posts: 3,455
Posted: August 27, 2004 at 3:18 PM / IP Logged
repairs by magic.... gotta love 'em
it may be you inadvertantly resoldered something or it may be that you still have an intermittent problem and it happens to want to work right now...... time will tell
more often than not, repairs by magic units always come back....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
mstacks
Member - Posts: 10
Posted: August 27, 2004 at 4:52 PM / IP Logged
open the amp and check for semicondutors that are loose  or  weak sodered causing it to shift
