One sub moving more then other
pimpincavy
Silver - Posts: 880
Posted: September 12, 2004 at 8:47 PM / IP Logged
I have 2 Orion 12" subs, they are 200W rms. They are running off a Memphis 250W class D amp. One of my subs is not moving as much as the other, I can tell just by looking at it that its not working as much as the other. What in the world could be causing this? I dont recall it being like that when I had them hooked up to my power acoustik amp. The subs are only a few months old and I have not been abusing them, so I dont think they are the problem.
Ravendarat
Platinum - Posts: 2,806
Posted: September 12, 2004 at 9:17 PM / IP Logged
One sub probally came unhooked. Pull em outta the box and check. Also check polarities on the subs and the wires going from the sub box to the amp.
padawan
Copper - Posts: 215
Posted: September 13, 2004 at 10:52 AM / IP Logged
Is the box single or dual chamber?
pimpincavy
Silver - Posts: 880
Posted: September 13, 2004 at 11:40 AM / IP Logged
Its a dual chamber box. Im faily sure a wire didnt come lose becasue the sub still works, its just not working on the same level as the other one.  Not to mention I soldered the wires on,so they arent goin anywhere.
fuseblower
Silver - Posts: 403
Posted: September 13, 2004 at 12:39 PM / IP Logged
Sounds like a weak voice coil or blown sub...  Also, verify your connection is not lose.
MBZ oe
Silver - Posts: 385
Posted: September 13, 2004 at 1:30 PM / IP Logged
Are they both fully broke in? I have experienced this a few times til they are fully broke in.
Something I always do is make the sub wires exactly the same length and roll up a little if one is too long. That way they the signal/current has the same distance to travel to each sub.
boom, boom, boom boom....
pimpincavy
Silver - Posts: 880
Posted: September 14, 2004 at 1:10 PM / IP Logged
I'll make sure when I get home today that a wire isn't lose.  The subs are about 2 months old, so I can return the one to the shop if it is infact a problem with the speaker itself.
jeffchilcott
Platinum - Posts: 2,483
Posted: September 14, 2004 at 7:12 PM / IP Logged
how are you running them? bridged into the same channel of the amp or to 2 diffrent channels. maybe your gain's are diffrent if running seprate channels
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
94legend
Silver - Posts: 237
Posted: September 14, 2004 at 8:25 PM / IP Logged
Might be out of phase check the wiring, also check your deck. If there bridged, check your gains.
Alpine Guy
Platinum - Posts: 2,478
Posted: September 14, 2004 at 8:58 PM / IP Logged
Test 1 sub at a time in the same box/chamber  and with the same wire, and the same test tone, , if theres a difference then its the sub, , , if they both work fine then look elsewhere, , do a process of elimination.  To do that you must do each test equally to make them accurate.
Page of 3
Tuesday, March 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
