bass blockers, capacitors
Ishinc
Copper - Posts: 109
Posted: September 13, 2004 at 1:56 AM / IP Logged
hey,
i did a seach on bass blockers and i wanted to know which capacitors i should get. it goes into a civic, with all the speaker replaced to sonys, no clue which model. what mf do you guys think i should get? i would like to have high and mids all around but no bass. thanks!
padawan
Copper - Posts: 215
Posted: September 13, 2004 at 10:33 AM / IP Logged
Here u go.... Bass Blockers
haemphyst
Platinum - Posts: 5,059
Posted: September 14, 2004 at 1:59 AM / IP Logged
i'm in the wrong damn business... i think i'm gonna go to snake-oil school! BWAHAHAHA 10 bux for a pair of non-polarized cheap-ass 50 øF electrolytic caps... !!! also, those frequencies seem WAY high... what frequencies are you trying to block? are you using an amp? if so, why not set the HP crossover on the amp? way better than a "Bass Blocker", with it's PFM description... (and i wish there was a way to let everybody HEAR my sarcasm...)
Charles_R_H
Copper - Posts: 122
Posted: September 14, 2004 at 3:56 PM / IP Logged
buy a deck with highpass crossovers if not an amp
you should always start with the deck when building a system
that's your source!
electronics run off of smoke, when you let the smoke out they stop working
Alpine Guy
Platinum - Posts: 2,478
Posted: September 14, 2004 at 4:19 PM / IP Logged
lookie here  https://www.the12volt.com/caraudio/cross4ohm.asp  , ,thats a chart for helping you decide, , you probably would want something in the 150hz- 200hz range, ,,then you can get some non-polarized caps for $5 all around at an electronics shop.
Ishinc
Copper - Posts: 109
Posted: September 14, 2004 at 9:24 PM / IP Logged
the deck is a pioneer deck, not bad...im am just rewiring a friends car because the person who installed it had no clue what they were doing...
i am aiming for 150hz, which caps should i be getting? i am not running this off of a amp, just directly off the deck without a highpass crossover.
the chart is a little confusing so i'm still not sure what to get....
stevdart
Platinum - Posts: 5,816
Posted: September 14, 2004 at 11:31 PM / IP Logged
150Hz high pass capacitor...for 1st order 6db/octave:  265 microfarads.  Here's one you can see shown at http://www.partsexpress.com/pe/pshowdetl.cfm?&PartNumber=027-370&DID=7, or this one to filter out below 125 Hz.
https://www.the12volt.com/caraudio/cross.asp
kgerry
Platinum - Posts: 3,455
Posted: September 15, 2004 at 10:27 AM / IP Logged
as an electronics guy i can tell you that the cost of non-polarized caps rises exponentially with the value ( uf )....
i can buy a bag full of 10 uf caps for a buck or two.....
but just try to buy a 400 or 500 or 600 uf non-polarized cap... they cost 10-15 bucks each !!!
in many cases i cant even buy them locally and am forced to buy from a couple thousand miles away or buy them from the car audio accessories suppliers.... of course i am stuck halfway between the Pacific and the Atlantic oceans and selections here aren't the best......
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
padawan
Copper - Posts: 215
Posted: September 15, 2004 at 6:54 PM / IP Logged
Yep, i bought a couple caps (non-polarized) from a local shop, to block bass from two front door 6X8s in a f-150 and i wound up paying $14 for two 260uF caps....So the ones crutchfield has aren't that bad in price....They will work just as well as any crossover to block lows if u get the right value capacitor....150Hz is about right....the X-over on my head unit is a 125Hz HPF and it works just the same as the bass blockers i put in for the dude with the 6X8s.
